OneX support on 4900M
Answered Question
Aug 30th, 2010
I'm designing a network containing two 4900M switches, which need to be linked to eachother using two 10Gb links. Instead of using X2 transceivers (X2-10GB-SR). I want to save costs and use the OneX converter (CVR-X2-SFP10G) with the TwinAx cables (SFP-H10GB-CU5M).
However, our partner tells me the OneX converter is only supported on the WS-X4908-10GE module (which is not part of my design).
I'm not convinced this is true, since the 4900M datasheet and the 10Gb compatibility Matrix do not mention this.
Does anyone have any experience with this kind of setup?
Thanks in advance.
Overall Rating: 4.5 (2 ratings)
Siebe Brouwer Thu, 02/24/2011 - 23:44
Hello Antonio,
The 4900M datasheet from Cisco is a bit unclear on this point, but this is supported!
Below are some show commands from my switch running this setup:
switch#show version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(54)SG, RELEASE SOFTWARE (fc3)
System image file is "bootflash:cat4500e-ipbasek9-mz.122-54.SG.bin"
cisco WS-C4900M (MPC8548) processor (revision 2) with 524288K bytes of memory.
Processor board ID JAE1435003D
switch#show inventory
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4900M 3 slot switch "
PID: MIDPLANE          , VID:      , SN: JAE1435003D
NAME: "Linecard(slot 1)", DESCR: "4900M 10GE (X2) with 8 10GE X2 ports"
PID: WS-C4900M         , VID: V07  , SN: JAE14380OUU
NAME: "Converter 1/3", DESCR: "Converter Module"
PID: CVR-X2-SFP10G     , VID: V02  , SN: FOC14363RL7
NAME: "TenGigabitEthernet1/3", DESCR: "SFP-10Gbase-SR"
PID: SFP-10G-SR        , VID: V02  , SN: AGD142960V6
switch# show interface Te1/3 status
Port      Name               Status       Vlan       Duplex  Speed Type
Te1/3                        connected    1            full    10G 10GBase-SR
switch#
Notice that both de CVR-X2-SFP10G and the SFTP-10G-SR are installed on interface Te1/3.
Best regards,
Siebe
