How to configure individual pre-share key on the hub for each spoke network.
Answered Question
Aug 30th, 2010
Hello Expert,
I about to set up a hub and spoke environment consist of several Cisco 2811 routers.
For my VPN we are using Dynamic multipoint VPN and for “IKE” we are using pre-share keys.
I would like to use different pre-share key for each location .
On the spoke I can easily achieve this ( inserting pre-share ) but from the Hub stand point I am unsure how to
achieve this ( separate key for each spoke network).
Attach is print screen (using SDM) of the Hub router .
Jomo
Correct Answer by Lei Tian about 6 years 5 months ago
Hi Jomo,
You can setup unique key for each spoke. It works same as point to point. If you are using single tier DMVPN, then the peer IP will be the tunnel end point.
Lei Tian
Correct Answer by Richard Burts about 6 years 5 months ago
Jomo
I have implemented many time a VPN with multiple point to point tunnels where each tunnel uses a unique ISAKMP shared key. And this works very well. You are correct in understanding that I have not implemented a multipoint VPN at the hub and tried to implement unique keys for each remote. I would think that this would work, but can not say from experience whether it does or not.
Rick
Overall Rating: 5 (2 ratings)
Richard Burts Mon, 08/30/2010 - 09:31
Jomo
the print quality of your screen shot was so poor that I can not read any significant details. But I will try to provide a response based on how it should work. The general approach for multipoint like this is to specify address of 0.0.0.0 in configuring the ISAKMP pre-shared key so that all remote VPN peers will match and will therefore all use the same pre-shared key. I would assume that it would work if you put a specific peer address and a specific (unique) shared key providing a unique value for each of the remote peers.
Rick
jomo frank Mon, 08/30/2010 - 10:21
Hello Rick,
Sorry for the poor quality of the screen shot.
I tested this  approach and it work okay .
But I am tring to impleament unique key for each remote peer for increase security.
From your response you think it may work but i guess you not too sure.
The other alternative maybe to setup separate point to point tunnel from hub to each remote location and then use specific (unique) keys.
Jomo
Correct Answer
Richard Burts Mon, 08/30/2010 - 10:44
Jomo
Rick
Correct Answer
Lei Tian Mon, 08/30/2010 - 11:10
Hi Jomo,
Lei Tian
jomo frank Mon, 08/30/2010 - 12:31
Hi Tian,
Thanks for the response, just need a quick confirmation.
Is this the ip of the Wan Interface ?
Lei Tian Mon, 08/30/2010 - 12:55
Hi Jomo,
Not sure what you use in your config. It is the runnel source configured on your spokes.
Lei Tian
jomo frank Mon, 08/30/2010 - 13:55
Hello Tian,
Thanks for response.
I understand the requirements now.
Keep up the good work
Jomo
