vrf-light in my Switch 3750
Aug 30th, 2010
Hi ,
i try to configure vrf-light in my two Switch 3750E ,
Firstly i try with the vesion (12.2(35)SE5  C3750E-UNIVERSAL-M ) .
the vrf is supported but when i went to configure EIGRP per vrf i had the message following :
FED_B(config)#router eigrp 1
% Remove all VRFs before configuring EIGRP
secondary , i upgrade the version to ( 12.2(53)SE1 C3750E-UNIVERSALK9-M )
but  this version is not supported by vrf-light . I had the message following when i try to configure  vrf-light :
FED_B(config)#ip vrf USER
% Invalid input detected at '^' marker.
FED_B(config)#ip v?
what can i do to configure vrf-light and the EIGRP per vrf ( for the load balacing)
Reza Sharifi Mon, 08/30/2010 - 08:31
Hi Mohamed,
VRF is defiantly supported on that image.  You many not have the correct license.  Get with SE  or sales guy to provide you with the key to enable it.
do a "sh licen" to see if you have the correct license.
Switch-B#sh license
Index 1 Feature: ipservices
        Period left: 0  minute  0  second
        License Type: Evaluation
        License State: Active, Not in Use, EULA accepted
        License Priority: Low
        License Count: Non-Counted
Related Content
