2851 12.4(1a) to 12.4(25d) Upgrade Snag
Answered Question
Aug 30th, 2010
I'm not sure where else to post this issue so sticking it in here.
I'm attempting to upgrade the IOS on a cisco 2851 router from 12.4(1a) to 12.4(25d). After deleting the 12.4(1a) .bin file from flash it shows about 57 megs free, plenty of space for the 12.4(25d) image, 38MB.
Using the 3COM tftp server I receive infinite out of sequence errors OOOOOOO's at exactly 87% of the file transfer (33,546,240 bytes). I let it run for several minutes during which the tftp server indicated the transfer process had halted. The only way to stop the console OOOOOOOOOO's was to close the tftp server, resulting in a timeout. After three attempts it stops at exactly 33,546,240 bytes. Keep in mind that the flash has over 57 megs free & I am not receiving a not enough space error of any kind.
I was able to transfer the old .bin file back onto the router due to its smaller file size luckily.
I verified the md5 checksum on the 12.4(25d) file as well.
Currently the router is still running 12.4(1a) and still needs the IOS upgrade to 12.4(25d). Could this be a bug with the 12.4(1a) image? Would upgrading to 12.4(3i) - (the only other image without known bugs who's file size would transfer before the tftp bugged out) - allow me to then transfer the 12.4(25d) image? Could this be a problem inherent with tftp?
I think I'm going to try putting on 12.4(3i) with tftp, then try 12.4(25d) with tftp to see if it rules out 12.4(1a) being a possible cause, then try transferring it with ftp if the tftp fails.
Thoughts?
Here is the show flash: WITH the original .bin file still in it, file transfer process was done after the 12.4(1a) .bin was deleted. I was able to put it back no problem using tftp after trying to put 12.4(25d) on.
12.4(25d) is about 4 megs larger than 12.4(1a).
OTC-DT>show flash:
-#- --length-- -----date/time------ path
1         1651 Aug 29 2005 19:44:50 +01:00 sdmconfig-28xx.cfg
2      3085312 Aug 29 2005 19:42:46 +01:00 sdm.tar
3       763392 Aug 29 2005 19:43:26 +01:00 es.tar
4       820224 Aug 29 2005 19:43:40 +01:00 common.tar
5         1038 Aug 29 2005 19:43:54 +01:00 home.shtml
6       113152 Aug 29 2005 19:44:08 +01:00 home.tar
7       504643 Aug 29 2005 19:44:22 +01:00 128MB.sdf
8      1208320 Aug 29 2005 19:44:36 +01:00 ips.tar
9          600 Mar 06 2008 14:07:14 +00:00 vlan.dat
10    32028828 Aug 29 2010 19:44:38 +01:00 c2800nm-advipservicesk9-mz.124-1a.bin
25464832 bytes available (38551552 bytes used)
OTC-DT>
Here is the log showing the failed upgrade process.
OTC-DT#copy tftp://172.16.21.5/c2800nm-advipservicesk9-mz.124-25d.bin flash:
Destination filename [c2800nm-advipservicesk9-mz.124-25d.bin]?
Accessing tftp://172.16.21.5/c2800nm-advipservicesk9-mz.124-25d.bin...
Loading c2800nm-advipservicesk9-mz.124-25d.bin from 172.16.21.5 (via GigabitEthernet0/1.2)
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!OOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO... [timed out]
%Error reading tftp://172.16.21.5/c2800nm-advipservicesk9-mz.124-25d.bin
Correct Answer by Nagaraja Thanthry about 6 years 4 months ago
Can you try to use tftpd32 as the TFTP server. There are some TFTP servers
that have limitations on the file size they can support.
http://tftpd32.jounin.net/tftpd32_download.html
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
droberts1214 Mon, 08/30/2010 - 08:22
I can give that a shot. I've never had any problems with the 3COM tftp server & large files though.
droberts1214 Mon, 08/30/2010 - 09:06
bam, that fixed it.
looks like the 3com tftp client cant transfer past a certain size.
glen.grant Tue, 09/21/2010 - 05:02
    Solarwinds tftpserver will also work well , it supports files up to 4 Gig  and its free also .
