Upgrading CUCM 6.0.1(b) to 6.1.2 not booting
Aug 30th, 2010
We have a problem on upgrading CUCM 6.0.1(b) to 6.1.2.
Since 6.1.2 can be directly upgraded from 6.0, downloaded ISO image and completed the upgrade installation.
After the upgrade when restarting with the newer version the system not booting. Seems the raid configuration got erased? No Hard disk detecting.
Server is IBM, MCS 7825I2-K9-CMA2. Do anyone met with this issue?
Thnx
John
gogasca Fri, 09/03/2010 - 11:12
  • Green, 3000 points or more
Are you still able to boot 6.0 ?
Try recovery CD to very HD integrity
Check if CSCta43460    Critical BIOS Update for MCS 7825-I2 fails to boot after Oct 1, 2009
applies
I recommend a TAC case on this one to take a look closely.
