Config-Register
Answered Question
I have been going through the config-register and I know the following to be true:
0x210X = 9600 baud
0x212X = 19200 baud
0x312X = 57600 baud
0xXXX0 = ROM
0xXXX1 = Bootstrap
0xXXX2 = Normal
The problem is the ignore value of 0x2142.
My question is "Does anyone know why it is 0x2142?"  If 2 is normal NVRAM then does that mean that the prefix of 0x214X is the ignore value?  What is special about it?  I am just really curious about how this value was selected to be the ignore value.  If anyone knows of any resources about config-register values and how they relate please let me know.
Correct Answer by Phillip Remaker about 6 years 6 months ago
0xXX2X = bit 5 set = 19200
0xX8XX = bit 11 set = 4800
0x1XXX = bit 12 set = 1200
See also http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_creg.html, Table 4.
When all bits are cleared (0) it is the default rate of 9600.
Overall Rating: 5 (1 ratings)
I have a new question now.
In that document I see the following:
5,11,12
0x0020, 0x0800, 0x1000
  • Console line speed
However it says that 0x2902 has a baud rate of 4800.  So I broke up the hex into the following:
0x0100 = no break
0x0800 = speed/baud rate
0x2000 = boots rom on failure
0x0002 = normal boot
0x2902
This tells me that 0x0800 is a 4800 baud rate, but that doesn't match what I was expecting.
The only explaination I can think of is the following:
if speed = !
     speed = 9600
elseif speed = 0x0800
     speed = 4800
or something very close to this.  Without me crunching the numbers to verify does anyone know what baud rates you get from 0x0020, 0x0800, and 0x1000?
