SA540W SSLVPN Issue
Aug 30th, 2010
SSL VPN Client gets a message "Maximum Limit on number of Active Tunnels has reached : cannot establish the tunnel:"  There is only 1 SSL user defined on the system.  I checked if I could reset the user bur could not do it.  Is there anyway to solve the issue?
Jibu Mathews
rmanthey Mon, 04/11/2011 - 15:52
With the latest firmware try under Status/VPN Status/SSL VPN Status. In this area you should be able to disconnect currently connected sessions.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
