SPA-2102 does not send DTMF tones for LD account after connection
Answered Question
Aug 30th, 2010
In order to send a long distance fax a 4 digit account code must be entered. This is a carrier service purchased by the customer for accounting. The faxes have worked for years this way. After installing the SPA-2102s It appears that they are not passing the DTMF tones after the connection is made and the carrier sends the second dial tone to challenge for the code.
When we make a test call with the handset on the fax machine we enter the accounting code and after a timeout period the carrier sends the recording that the call can not be completed. We then made a call from a different handset and did not enter the code at all and we got the same recording.
It seems to me that the DTMF codes send through the SPA-2102 from the fax machine would be treated as regular audio and should be passed. What am I missing?
Correct Answer by Alberto Montilla about 6 years 6 months ago
Dear Sir;
Please set the following settings on the SPA2102 Line where the fax is connected via VoIP:
(1) DTMF Tx Method: Inband
(2) DTMF Tx Mode: Normal
Submit changes and please let me know the results.
Alberto
Overall Rating: 5 (1 ratings)
Correct Answer
Alberto Montilla Wed, 09/08/2010 - 05:12
  • Cisco Employee,
Dear Sir;
Alberto
grayh_2 Wed, 09/08/2010 - 06:59
Thank you Alberto. That worked
Gray Heustess
Systems Engineer
ConvergeNet, Inc.
Motorola Enterprise Mobility business (EMb)
Partner Select
Office:  (772) 469-2565
Mobile:  (386)-527-1081
Alberto Montilla Thu, 09/09/2010 - 08:04
  • Cisco Employee,
Dear Sir;
Can you please set the question as answered? this would help others to find it.
Alberto
