Health Status for Failed Applications ---> Red
Hello experts,
Im actually facing some issues with a 4260.
Health Status for Failed Applications                   Red
Health Status for Signature Updates                     Green
Health Status for License Key Expiration                Green
Health Status for Running in Bypass Mode                Red
Health Status for Interfaces Being Down                 Green
Health Status for the Inspection Load                   Green
Health Status for the Time Since Last Event Retrieval   Green
Health Status for the Number of Missed Packets          Green
Health Status for the Memory Usage                      Green
Health Status for Global Correlation                    Green
Health Status for Network Participation                 Not Enabled
It is in bypass mode as you can see.
I cannot get statistics neither.
IPS1# sh statistics virtual-sensor
Error: getVirtualSensorStatistics : Control transaction cannot be completed at this time
IPS# sh statistics analysis-engine
Error: getAnalysisEngineStatistics : Control transaction cannot be completed at this time
I have beeing  looking in the internet for a solution or a reason why this is happening. It seems that this is something not documented.
Can someone please help me. I can restart the IPS right now. Would it be helpful if I restart the MainApp with a service account?
6 Replies 6
Jia Liu
It looks like the IPS may have crashed.  Can you try rebooting the sensor?
I'm going to try to reboot the sensor tomorrow. I will let you know if it worked.
Can you please attempt to gather a "show tech" from the device? If you have already rebooted the device, the output of a "show tech" will still be useful. You are welcome to email it directly to me.
Thank you,
Blayne Dreier
blayne@cisco.com
Cisco TAC IDS Team
**Please check out our Podcast**
TAC Security Show: http://www.cisco.com/go/tacsecuritypodcast
Blayne I always follow the podcast with White and Magnus.
Thank you for all the information and help.
Awesome! Thanks for following us. We have also begun work on an IPS specific podcast, the "TAC IPS Media Series."
https://supportforums.cisco.com/docs/DOC-12759
Your 4260 has an incredibly high number of Tuned/Enabled signatures, which is causing sensorApp to run at 99% CPU. Many sequentially numbered signatures are tuned. Did this issue correlate to the enabling of a large amount of signatures?
I suggest reviewing your current configuration and noting those signature tunings that you truly require. Then default your signature configuration and only apply those signature tunings that are needed.
Your sensor also encountered CSCta96144, which is fixed in IPS 7.0(4). You can review the bug w/ the CCO Bug Toolkit: http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
Thank you,
Blayne Dreier
Cisco TAC IDS Team
Thank you very much for the help. Im actually working with a company that bought 2 4260 and a 4270 They need to tunned the signatures based on their needs that's why there are so many tunned signatures.. In many signatures I only modified the action which change the sig to a tunned signature. I will try to do the upgrade next week to avoid hitting the bug.
Thank you again for the help Blayne.
