Pavol Golis Mon, 08/30/2010 - 14:20
I would go with 12.2(33)SXH7, that train is already stable - 7th maintenance release of bugfixes. SXI4a might not be at that level of code maturity.
Reza Sharifi Mon, 08/30/2010 - 14:51
Do a comparison of the SXI and SXH using Cisco feature navigator.  You will see that SXI has a lot more features than SXH.  In addition and according to Cisco most features are being added to SXI.  For example: with SXI4 and 4a dual sup per device is supported.  So, I would test SXI4a in the lab and if you don't find any major bugs use it.
Reza
Related Content
