ACE: How does one probe "rservers redirect" in "serverfarm redirect"?
Answered Question
Aug 30th, 2010
Probes can be used with serverfarms of type host
probe http WEB_SERVERS
interval 5
passdetect interval 10
passdetect count 2
request method get url /index.html   expect status 200 200
  !--- Probe used to detect the status  !--- of the servers in the serverfarm.
rserver host S1
ip address 192.168.0.200
inservice
rserver host S2
  ip address 192.168.0.201
  inservice
rserver host S3
  ip address 192.168.0.202
  inservice
rserver host S4
  ip address 192.168.0.203
  inservice
serverfarm host SF-1
  probe WEB_SERVERS
  rserver S1
   inservice
  rserver S2
   inservice
  rserver S3
   inservice
  rserver S4
   inservice
When it comes to "serverfarm redirect" how would one emulate the probing to work as above. (When one is loadbalancing servers of type redirect, the probe command is not available for serverfarm redirect SF-2)
Its also not possible to mix reservers of type redirect with serverfarm of host. If it was possible, This would have answered my question, which is.
How does one emulate the probe functionality found in rsever host and serverfarm host in serverfarm redirect?
Correct Answer by yushimaz about 6 years 9 months ago
Probing a redirect server was supported on A2(3.2) or later.
So, you can use the probe configuration on 'serverfarm redirect', where 'ip address [ip_address] routed' option is required.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_x/Release/Note/RACEA2_3_X.html#wp620109
Unfortunately, 'rserver host' and 'rserver redirect' cannot exist together in the same serverfarm since 'serverfarm host' is
for real server and 'serverfarm redirect' is for redirect rserver.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/command/reference/config.html#wp1117844
When you use backup serverfarm as below, you can use both serverfarms. However, you cannot use primary serverfarm
and backup serverfarm at the same time.
policy-map type loadbalance first-match lb
  class class-default
    serverfarm SF1 backup SF2
Yuji
Overall Rating: 5 (2 ratings)
litrenta Tue, 08/31/2010 - 07:05
  • Cisco Employee,
a redirect serverfarm would only have redirect servers in it. A redirect
server is not a real server but rather an internal structure in the ace with the specific
purpose of performing an http redirect based on an appropriate load balancing policy.
Since it is an internal structure it cannot be probed (it has no ip address ) it is always operational as long as it is inservice.
Correct Answer
yushimaz Tue, 08/31/2010 - 18:24
  • Cisco Employee,
  class class-default
Yuji
edgarfc254 Fri, 09/03/2010 - 00:02
Was running A2(3.0) and I have upgraded to A2(3.2). Now probing of redirect servers is possible.
Thanks yushimaz
