RV120W gateway to gateway to ASA 5510
Aug 30th, 2010
I am trying to establish a vpn tunnel from the rv120 to the 5510
so that I can use an IP phone over cable for home/office back to network.  I have setup the policies but am getting the following messages when I try and connect the tunnel.
4 Aug 30 2010 20:38:54 713903    Group = DefaultRAGroup, IP = 24.171.63.218, Error: Unable to remove PeerTblEntry
3 Aug 30 2010 20:38:54 713902    Group = DefaultRAGroup, IP = 24.171.63.218, Removing peer from peer table failed, no match!
I am not using the defaultragroup - i created a group on my 5510 and setup the rv120 to use that group.
What am I missing?
David Hornstein Sat, 09/04/2010 - 16:36
  • Gold, 750 points or more
Hi Gail,
I haven't got a RV120W myself, but a VAR said he had no trouble configuring a tunnel after he played with Perfect Forward Secrecy (PFS) settings. Ok cool.
I got a old RV042 up and running between a ASA5505.  My screen captures might assist you. But basically I matched the ISAKMP and IPSec Settings on both units. So have fun tweaking.
When you get the solution, please paste your results  and monitor this site for possible solution.
regards dave
