remote branch design...
Aug 30th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
From a design point of view, would it be best to the switch operate as layer 3? I want the switch to share the load with the router. The site usually has 50 concurrent connections.
What would be best option?
Many thanks
Richard Burts Mon, 08/30/2010 - 09:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
With a branch size of about 50 I think it will not make a significant difference. The diagram shows 2 access layer switches connected to a single distribution layer switch. In that situation I believe that it is best if the distribution switch is a layer 3 switch and is doing routing for inter vlan communication. In this way the layer 3 switch carries responsibility for routing within the branch and the router is able to focus on routing for outside of the branch.
Rick
