newbie question : object and object group
Aug 30th, 2010
hi, i am quite new to ASA firewall
just wanna ask is the below statement correct
object network users
subnet 10.10.10.0 255.255.255.0
description vlan 10 Users
object network IP_Phone
subnet 10.10.20.0 255.255.255.0
description vlan20 IP Phone
object-group network Inside_Network
network-object object users
network-object object IP_Phone
for the object-group network Network_Mgnt, the network-object object users statement is it equivalence for network-object 10.10.10.0 255.255.255.0?
thanks
Nagaraja Thanthry Mon, 08/30/2010 - 19:53
  • Cisco Employee,
Yes, you are correct. If you look at the output below:
access-list test line 1 extended permit ip any object-group Inside_Network
access-list test line 1 extended permit ip any 10.10.10.0 255.255.255.0
access-list test line 1 extended permit ip any 10.10.20.0 255.255.255.0
The first line is the one that we configure in the firewall and it expands
to the next two lines when building the ACE.
Hope this helps.
NT
yong khang NG Tue, 08/31/2010 - 00:14
hi, about some design quetion
basically my network topology look like the diagram illustrated.
a. outside interface facing to public internet.
b. inside interface
- physically is connect to core switch
- logically this interface will have sub-interface for different zone
- CSC module physically connect to core switch, which is fall to vlan200 management
c. MISC
- the switch will doing inter-vlan routing
- one email server reside in vlan100 server (10.10.100.25 --> 202.152.87.25), which need to do NAT for this.
i try to use the object and object-group to make it categorize (shown in diagram)
my question is:
1. so i need to explicitly create the ACL fot outside remote access?
is it the correct way for my ACL?
example: access-list mgnt_zone_access_in extended permit ip any any
2. so i can apply either object or object-group on the ACL or NAT?
3.  beside email server know gonna have static NAT, should i do any NAT for the network? (well, your suggest are welcome, what-if you meet this kind of topology, what would you do..)
4. what does it mean for this NAT+ACL hybrid?
example : access-list mgtn_zone_nat0_outbound extended permit ip 10.10.200.0 255.255.255.0 10.10.10.0 255.255.255.0
thanks
