Accessing the CAR database
Aug 30th, 2010
I want to know the Quality experienced by each call in my network. I would like to create my own reports and alerts for the same. I know that the CAR tool already does that. Is there some way that I can access the CAR database, so that I can report on the data the way I want? I dont want to process the CDR/CMR records on my own. Ideally I would want to leverage the CAR tool to give me the processed data.
Does CAR use the same Informix db as the Call Manager? If yes, I have the Database dictionary. Can someone point out which tables that I should be looking at?
Any clue would be of great help.
Thanks in advance
Roycey
Overall Rating: 4 (1 ratings)
Aaron Harrison Tue, 08/31/2010 - 00:45
It's not the same database as the CCM DB, so the normal schema document doesn't cover it.
In fact, I'm not aware of ever seeing a published schema doc for CAR at all - though the actual CDR APIs are well-documented (http://developer.cisco.com/web/sxml/docs).
If you want to take a look at the CAR DB, you can get a list of tables from it like so (from an SSH session to the server running CAR):
run sql select tabname from car:systables where tabid >99
Using that list of tables you can take a look at each one:
run sql select first 5 from car:tbl_event_log
Aaron
Please rate helpful posts...
Roycey Cheeran Tue, 08/31/2010 - 05:47
Hi Aaron
Thanks for the speedy response. Just a few more doubts. Does CAR run on a MS SQL db? Does the CAR db reside on the Call Manager or some where else.   Will the CAR user name and password be sufficient to access the db? I need to know the kind of DB the CAR DB is before I try to connect to it using SSH. Currently I access the CAR UI using the Browser.
Roycey
Related Content
