allow port forwarding between port 100 to 1500 on ASA 5510?
Aug 30th, 2010
Dear all,
I would like to allow port forwarding on ASA 5510 between port 100 to 1500, but i don't know which command that allow allow of port?
if only one port i can do like
static (inside,outside) tcp interface 25 25 netmask
but i want to allow start from port 100 to 1500( i mean that 100,101,102,1003----1498,1499,1500)
How can we do on thies?
Best Regards,
Federico Coto F... Tue, 08/31/2010 - 06:10
Port forwarding will allow to redirect a connection from one port to another (single port).
So, you can have multiple statements for multiple ports.
But if you're looking for a ''range'' option, there's no such thing.
You either redirect based on multiple entries (one for each port) or use another IP address that you can statically NAT.
Nagaraja Thanthry Tue, 08/31/2010 - 06:16
If you want to forward a whole range of ports from outside to inside,
upgrade the code to 8.3. In 8.3, you can forward a range of ports from
outside to inside.
object network test1
object network test2
object service ports
service tcp source range 100 1500
nat (inside,outside) source static test1 test2 service ports ports
Hope this helps.
