871 - second alternative WAN connection
Aug 31st, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:Standardowy; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
Hey
I want to make backup internet connection on 871 Cisco router.
I made belowe steps
  • One of the Vlan 1 port was changed into Vlan 2.
  • Vlan 2 now have static IP which is address for      second ISP.
  • Added route with priority 2.
Everything works fine, routing switching dynamically from one ISP to another.
Unfortunately I can’t resolve the problem of NAT.
In configuration is:
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.9.0 0.0.0.255
How to change that NAT will switch automatically and translate addresses depends from routing.
Overall Rating: 3 (1 ratings)
Federico Coto F... Tue, 08/31/2010 - 06:35
  • Green, 3000 points or more
Use a route-map.
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
route-map ISP1
  match ip address 101
  set ip next-hop x.x.x.x
route-map ISP2
  match ip address 102
  set ip next-hop y.y.y.y
ip nat inside source route-map ISP1 interface Fas0/0 overload route-map ISP1
ip nat inside source route-map ISP2 interface Fas0/1 overload route-map ISP2
The above example assumes the following:
192.168.1.0/24 = is the internal network
x.x.x.x = is the IP of the Fas0/0 (assuming that's the primary internet connection)
y.y.y.y = is the IP of the Fas0/1 (assuming that's the secondary internet connection)
Additionally you can use the IP SLA feature to track the routes.
Federico.
pwolsza_wolfik1 Fri, 09/03/2010 - 02:24
Thanks for information.
Unfortunately something is wrong because ISP1 is working but the ISP2 not.
Where I made a mistake, maybe vlan is the problem??
This is conf.:
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
description WAN2
switchport access vlan 2
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address 10.14.62.83 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.9.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
interface Vlan2
ip address 192.168.11.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.14.62.81
ip route 0.0.0.0 0.0.0.0 192.168.11.1 2
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map ISP1 interface FastEthernet4 overload
ip nat inside source route-map ISP2 interface Vlan2 overload
logging trap debugging
access-list 101 permit ip 192.168.9.0 0.0.0.255 any
access-list 102 permit ip 192.168.9.0 0.0.0.255 any
no cdp run
route-map ISP2 permit 10
set ip next-hop 192.168.11.1
route-map ISP1 permit 10
set ip next-hop 10.14.62.81
pwolsza_wolfik1 Tue, 09/07/2010 - 23:21
Below the configuration with solved problem.
Thanks for sugestion:
no cdp run
route-map ISP2 permit 11
match interface Vlan2
match interface FastEthernet4
continue 11
