Good day
We are currently deploying the Cisco unfied guest access solution (as per best practices). The one area that is alittle grey is the actual placement of the guest server. Could you please comment on wether the server should be place in the DMZ with the anchor controller, or on the inner side of the DMZ. Are there pros and cons as to where it is placed.
Kind regards
Roy.
