Cisco Unity Connection root account password
Aug 31st, 2010
How could I get the linux root account password for my lab unity connection? I successfully created the account but it gives me a passphrase is there a tool to convert that into a password?
Jaime Valencia Tue, 08/31/2010 - 04:16
That only Cisco TAC can provide and only for legitimate troubleshooting purposes or to apply the workaround of a bug.
Look at htluo's blog, there was a non-supported method of creating a root account. It clearly mentions that the procedure should only be performed on non-production servers so if all you want is to play around with the lab server you can do it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
