wait for an agent with best skill and loop after that.
Answered Question
Aug 31st, 2010
I want to solve the following situation:
I have three skills (A, B, C) with different skill levels for each agent. C is the "everything else topic" . The caller selects the toppic which is equivalent to the skills. Of course I want the call to be forwarded to the best skilled agent.
Let's assume the calles selects topic A and all Agents with Skilllevel > 5 for  A are currently talking. I want to hold the caller for 30 seconds to wait for one of these Agents. After 30 seconds I would like to forward the call to the agent with the highest skill level A.
And of course I want to avoid the caller to wait the 30 seconds if no Agent with skilllevel > 5 is on duty.
Currently I have one CSQ for each topic and I expect a skillevel > 5 for the agents serving this CSQ.
At first I put the call in the CSQ for A and play a prompt with 30 seconds MOH, if no agent becomes available I put the call in the CSQ for C and loop the caller there. But now the best agent for C get's the call.
I appreciate any hints on that.
Christian
Correct Answer by Anthony Holloway about 6 years 8 months ago
Don't queue in C unless there are at minimum X ready agents.  You can define X as 1 to start, then play with the number to see how it affects wait times and dequeues.
select resource (csq_a)
     connected
          end
     queued
          label loop
          ready_in_c = get reporting stats(csq_c, ready resources)
          if (ready_in_c >= 1)
               true
                    /* at least one person idle and ready in C
                    select resource(csq_c)
                         connected
                              end
                         queued
                              /* oops! we just missed them. */
                              /* if ready_in_c was > 1, this dequeue step will not execute */
                              /* instead, the script jumps to the select resource step for csq_c */
                              /* and tries the next agent automatically.  only when there are no */
                              /* idle and ready agents do we dequeue the caller, so that an agent */
                              /* servicing csq_a can take the call */
                              dequeue(csq_c)
               false
                    /* no one available in C */
               play prompt(you are important to us)
               call hold
               delay 30
               call unhold
               goto loop
Overall Rating: 5 (1 ratings)
Correct Answer
Anthony Holloway Tue, 08/31/2010 - 09:10
  • Purple, 4500 points or more
     connected
          end
     queued
          label loop
               true
                         connected
                              end
                         queued
                              dequeue(csq_c)
               false
               call hold
               delay 30
               call unhold
               goto loop
christiangauer Thu, 09/02/2010 - 01:41
That's a very nice approach. Thank you. Solves the "first step"
Will this route the call still to the best skilled Agent for Topic A?
The agents in C might also have a skill of A, which is <5. Let's assume Agent Bob in CSQ C has a skill level of 4 for skill A, and Agent Peter in CSQ C has skill level of 1. Both agents are idle. In CSQ A there is no agent idle.
How can I make sure Bob will get the caller?
