Cisco 877 show dsl interface atm
johnlloyd_13
Level 9
Level 9
hi experts,
i've got a Cisco 877 router connected to an ADSL link. i'm using the show dsl interface atm just to have a look on its performance. i've tried to search on Cisco website on how to interpret the output but a blog gave me more info (http://itknowledgeexchange.techtarget.com/cisco/tag/dsl/). my question now is, what readings do i consider? is it on the left (ATU-R) or on the right (ATU-C)? thanks!
877ROUTER#sh dsl int atm0
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT)
ITU STD NUM:     0x01                            0x01
Vendor ID:       'ALCB'                          'ALCB'
Vendor Specific: 0x0000                          0x0000
Vendor Country:  0x00                            0x0F
Capacity Used:   31%                             85%
Noise Margin:    34.0 dB                         10.0 dB
Output Power:    16.0 dBm                        12.0 dBm
Attenuation:     10.0 dB                          6.0 dB
Defect Status:   None                            None
Last Fail Code:  None
Selftest Result: 0x00
Subfunction:     0x15
Interrupts:      1453 (2 spurious)
Activations:     3
Init FW:         embedded
Operartion FW:   embedded
SW Version:      3.919
FW Version:      0x1A04
                 Interleave             Fast    Interleave              Fast
Speed (kbps):             0             3040             0               768
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Bit Errors:               0                0
BER Valid sec:            0                0
BER Invalid sec:          0                0
LOM Monitoring : Disabled
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 6 6 7 9 9 A B B C
10: B B B B B A A A A 9 8 8 8 7 0 0
20: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 2
30: 2 2 3 3 4 4 4 4 4 4 4 5 5 5 5 5
40: 5 5 5 5 5 5 5 5 5 5 5 5 6 5 5 6
50: 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6
60: 2 6 6 6 6 6 6 6 6 6 6 6 6 5 5 5
70: 5 6 6 5 5 6 5 5 5 5 5 5 5 5 5 5
80: 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5
90: 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5
A0: 5 5 5 5 5 5 5 5 5 4 5 4 4 4 4 4
B0: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
C0: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
D0: 4 4 4 4 4 4 4 4 4 3 3 3 3 3 2 2
E0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
F0: 2 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Training log buffer capability is not enabled yet.
adnane dakna
ATU-R refers to the router side and ATU-C refers to ISP DSLAM side
ai.solutions
ATU-R is your downstream and ATU-C is your upstream.
Thanks for your inputs! I've found the answer to my question not so long ago
