Integration of CSM with ACS
Aug 31st, 2010
Dear,
   I am using csm 3.3.0 and ACS 4.2. I followed all of the procedure for integrating csm with ACS according to cisco document.But when i applying in CSM it is showing that AAA client is not configured.But actually i registered CSM Server as AAA client in ACS.Please provide me some way to trouble shoote this problem..
Thanks in advanse..
skalaven Tue, 08/31/2010 - 11:17
You could try and check few things
Is the CSM server contained within a Network Device Group in ACS?
Which shared secret key are you specifying within Common Services' AAA Mode
Setup?  ACS uses the shared secret defined at the GROUP level rather than the
one defined at the device level.
Restart daemon manager
Go to ACS' Shared Profile Components and check to see if the default
user roles are registered for Ciscoworks Common Services and Cisco Security
Manager.  Also click on one of the default user roles to see if the permissions
display or you receive an error.  Check the ACS Reports and Log for TACACS+
Administration and Failed Attempts.
Hope this helps.
--Sunil
Naisamuddin pk Fri, 09/03/2010 - 00:26
Dear Sunil.
               Thanks for your valuable reply.Accrding to your suggession i checked everything and still it is not solved.I am follwing the results
1.I am using same shared key foe NDG and CSM,I am using user csmadmin in CSM and i created this user  in ACS as administrator
2.I am not seen any Defualt user in ACS shared components.Only the following  options are there.
       1)Radius authorisation component
       2)Network Access Restrictions
       3)Shell Command Authorisation sets
      4)PIX/ASA Command authorisaion sets
Also i tried restating daemon service.
Based on this result plese help me to resolve this problem..
Thanks and Regards
Naisamuddin Pk
Mike Bailey Thu, 06/09/2011 - 02:59
Just had the exact same problem with CSM 4.1 and ACS 4.2.1, problem was the Windows Firewall on the ACS server preventing the CSM server connecting fully to the HTTP/HTTPS interface of ACS.
Mike
