CUVA no video at calls between CME
Aug 31st, 2010
Hello!
We have two sites connected through a GRE-tunnel.
SiteA#sh ver
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
voice service voip
h323
  call start slow
dial-peer voice 2 voip
destination-pattern 2..
session target ipv4:10.10.1.2
telephony-service
video
   maximum bit-rate 384
service phone videoCapability 1
ephone-dn  1  dual-line
number 101
ephone  1
  video
  mac-address 001E.135C.EECF
  type 7960
button  1:1
SiteB#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
voice service voip
h323
   call start slow
  destination-pattern 1..
  session target ipv4:10.10.1.1
telephony-service
  video
  number 201
ephone  1
   video
   mac-address 001F.297A.A3CA
   type CIPC
  button  1:1
When the user of SiteB tries to establish a video call with the user of SiteA there is no remote video, while the the local video is present. When the user of SiteA tries to establish a video call with the user of  SiteВ there is no remote and local video. Voice calls are established normally.Local video calls established normally.
On both site CUVA Application Version 2.2.1.7, CUVA CDP Driver 3.0.
Please, advise ways of the decision of the given problem. Thank you.
Felipe Garrido Wed, 09/01/2010 - 07:14
  • Cisco Employee,
Can you collect the following information.
show ephone phone-load
show ephone register
Place all call between the two endpoints and collect the following command output while the call is active
show call active voice brief
show call active video brief
Can you make video call between two phone at the same site?
-Felipe
Andrei Fokin Wed, 09/01/2010 - 22:32
Hello, Felipe.
1)
Yes. No problem.
2)
SiteA#sh ephone phone-load
DeviceName        CurrentPhoneload       PreviousPhoneload      LastReset
SEP001E135CEECF
   8.0(5.0)               7.2(T0.23)             Initialized
SiteA# sh ephone registered
ephone-1[0] Mac:001E.135C.EECF TCP socket:[91] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 11/9 max_streams=0 + Video
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:10.10.1.100 51025 Telecaster 7960  keepalive 19533 max_line 6 available_line 4
button 1: dn 1 number 101 CH1   IDLE         CH2   IDLE         shared with monitor-ring
Preferred Codec: g711ulaw
SiteB#sh ephone phone-load
SEP
001F297AA3CA    7.0.4.0                7.0.4.0               UCM-g`jp{r` no
SiteB#sh ephone registered
ephone-1[0] Mac:001F.297A.A3CA TCP socket:[12] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 15/12 max_streams=5 + Video
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:10
IP:10.10.2.100 1460 CIPC  keepalive 28 max_line 8 available_line 8
button 1: dn 1  number 201 CH1   IDLE         CH2   IDLE         overlay shared
overlay 1: 1(201) 11(3965) 12(3965) 13(3965) 14(3965) 15(3965) 16(3965)
3)
SiteA# show call active voice brief
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 0
SiteA#show call active video brief
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 1
SCCP call-legs: 0
Total call-legs: 2
1904 : 61847 1390688580ms.1 +3580 pid:20000 Answer 101 active
dur 00:00:31 tx:0/0 rx:0/0
Tele 50/0/1 (61847) [50/0/1.0] tx:0/0/0ms g729r8 noise:0 acom:0  i/0:0/0 dBm
1904 : 61848 1390689890ms.1 +2270 pid:2 Originate 201 active
dur 00:00:31 tx:1588/31760 rx:2372/230326
IP 10.10.2.1:19482 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
SIP call-legs: 0
H323 call-legs: 1
SCCP call-legs: 0
Total call-legs: 2
SiteB# show call active voice brief
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 0
SiteB#show call active video brief
SIP call-legs: 0
H323 call-legs: 1
SCCP call-legs: 0
Total call-legs: 2
1904 : 3766 1175778890ms.1 +2150 pid:2 Answer 101 active
dur 00:00:15 tx:1158/126202 rx:792/15840
IP 10.10.1.1:17286 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 TextRelay: off
1904 : 3767 1175778910ms.1 +2090 pid:20000 Originate 201 active
dur 00:00:15 tx:0/0 rx:0/0
Tele 50/0/1 (3767) [50/0/1.0] tx:0/0/0ms g729r8 noise:0 acom:0  i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 1
SCCP call-legs: 0
Total call-legs: 2
Andrei Fokin Fri, 09/10/2010 - 06:44
The problem has been solved by downgrade IOS from version 124-24.T1 on version 124-15.T4. On version 124-24.T1 video calls beetwen remote CME were established about one of thirty attempts.
Related Content
