Using internal SSL Certs for Webview and Reskill (ICM 7.2.X)
Aug 31st, 2010
I would like to use corporate ssl certs for webview and reskill to avoid the user having to install the self signed certificate on the local machine. Has anyone any experience of this? Can it cause any unforseen problems?
My plan for webview is to create the certificate request in IIS for the default website, use this csr to generate the cert, then complete it by uploading the certificate.
For reskilling, I will assume I will have to do some command line stuff here ...
eg: keytool -genkey -keyalg RSA -keystore hostname.key
to create the key,
keytool -certreq -keyalg RSA -keystore hostname.key -file hostname.csr
to create the csr, and
keytool -import -trustcacerts -alias tomcat -file hostname.cer -keystore hostname.key
to import the new cert
Suggestions or comments for anyone who has tried this before would be appreciated.
Brian
david.macias Mon, 06/09/2014 - 06:34
I've never done it on a version so old, but at the end of the day it's just IIS and Tomcat and importing an SSL cert is very standard.
david
