08-31-2010 07:25 AM - edited 03-06-2019 12:45 PM
Hi All,
Just doing a quick sanity check on my decision before I purchase but have found some conflicting information that I do with help clarifying!
I'm purchasing a 3750X-48 and need to run OSPF, can I do this with IP Base? The Cisco product page would appear to say Yes, I quote:
"Software versions
But from everything else I've read on these forums only static routing is available in IP Base along with RIP, can anyone shed some light on this? By Routed Access does it simply mean OSPF can be used but only as a Stub area (much like EIGRP with IP Base?)
Jay
Solved! Go to Solution.
08-31-2010 05:32 PM
Newly released IOS version 12.2(55)SE support OSPF v1 ONLY.
08-31-2010 07:46 AM
Can you provide your link? The links I am reading said OSPF is in IP Services.
"The LAN Base feature set offers enhanced intelligent services that includes comprehensive Layer 2 features. The IP Base feature set provides baseline enterprise services in addition to all LAN Base features. IP Base also includes the support for routed access, StackPower, and MACsec. The IP Services feature set provides full enterprise services that includes advanced Layer 3 features such as Enhanced Interior Gateway Routing Protocol (EIGRP), Open Shortest Path First (OSPF), Border Gateway Protocol (BGP), Protocol Independent Multicast (PIM), and IPv6 routing such as OSPFv3 and EIGRPv6. IP Services feature set also includes the Embedded Event Manager (EEM) and IP service-level agreements (SLAs) initiator functionalities. All software feature sets support advanced security, QoS, and management features. The IP Services feature set is only available as an upgrade option at the time of ordering or through a license at a later time; there is no dedicated IP Services switch model."
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
Figure 2
jerry
08-31-2010 07:51 AM
Hi Jerry,
Thanks for your reply, I was looking at the actual product page for the 3750-X located here: http://www.cisco.com/en/US/products/ps10745/index.html
If you scroll to about mid way down the page it has a "Software Versions" section in which it states IP Base includes OSPF for Routed Access.
Jay
08-31-2010 08:07 AM
I see. What version are you running in your switch right now. The output of show ver would help.
jerry
08-31-2010 08:09 AM
Hi Jerry,
I haven't actually bought the switches yet, I am in the process of purchasing them and in doing so and trying to ensure I buy the right software version for the requirements (which is to run OSPF).
J
08-31-2010 08:27 AM
I see. Well, my internal research said 12.2(55)SE will supports OSPF in ipbase. However, I can't find any public documentation or confirmation on software advisor in regard which release has it.
jerry
08-31-2010 05:32 PM
01-16-2014 12:25 PM
Just an update, version 15.0(2)SE5 supports OSPFv3 iwth IPBASE. I was turning up IPv6 and IP Services is mentioned in documentation:
WS-C3560X-24 15.0(2)SE5 C3560E-IPBASEK9-M
Minimal Config:
ipv6 unicast-routing
ipv6 router ospf 1
router-id 10.8.8.109
redistribute connected
interface Vlan88
no ip address
ipv6 address 2607:F598:0:4::3:6/112
ipv6 enable
ipv6 nd ra suppress
ipv6 ospf 1 area 0.0.0.0
09-01-2010 03:25 PM
Thanks for the ratings.
10-20-2010 07:46 AM
Jonathan,
Have you tested this yet? Is it full ospf capable? Or is it just EIGRP stub? The release notes say ospfv2 and 3 are capable
11-08-2010 06:14 AM
OSPF for routed access is in IP Base. The definition of the feature and usage guidelines are described in the release bulletin:
HTH,
Marco
