Config archive for Cisco 4404 WLC devices
Aug 31st, 2010
Nodes are discovered properly, with the correct icon, and inventory updated.... but when we try to download config, we got:
*** Device Details for XXXXXXX ***
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==> Telnet,TFTP,SSH,RCP,HTTPS
Execution Result:
Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings
We have configured only HTTPS credentials, because others are not permited, isn't it?
Telnet through port 22 works fine (i have read about https://supportforums.cisco.com/message/3053616#3053616)
Overall Rating: 4 (1 ratings)
mserranocisco Wed, 09/01/2010 - 07:01
in dcmaservice.log:
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,updateArchive,1941,Sync Archive for 4 devices - Sync Archive
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,updateArchive,1955,Number of devices in fetch Q = 0
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,addToDeviceIdToReqIdMap,2289,Device Id 7 already in Q
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,compareDeviceWithDevicesinRunningThreads,59,inside compareDeviceWithDevicesinRunningThreads method
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,compareDeviceWithDevicesinRunningThreads,60,Total running threads:5
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,compareDeviceWithDevicesinRunningThreads,65, Running Thread Thread-7
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,compareDeviceWithDevicesinRunningThreads,67,Device Id :6
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,compareDeviceWithDevicesinRunningThreads,68,Device Name :PEDRWLS101
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,compareDeviceWithDevicesinRunningThreads,65, Running Thread Thread-10
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,compareDeviceWithDevicesinRunningThreads,67,Device Id :7
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,compareDeviceWithDevicesinRunningThreads,68,Device Name :PEDRWLS102
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,addToDeviceIdToReqIdMap,2289,Device Id 6 already in Q
[ Wed Sep 01  15:54:34 CEST 2010 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,updateArchiveIfRequired,2055,Compared the device with running thread devices.Adding to Fetch Q
mserranocisco Wed, 09/01/2010 - 04:46
If I run a snmpwalk, it works properly, but if I check credentials, I got "Failed to get value" for Read Community :-(
If I try to run CiscoView for those nodes:
Error
Message
Cannot access the required SNMP object.
Cause
This problem could be due to a restricted SNMP view setting or the wrong SNMP credentials.
Action
Please check the SNMP view setting on the device and SNMP credentials.
But SNMPWalk is working!
Joe Clarke Wed, 09/01/2010 - 21:49
You can only use telnet or SSH to get configs from WLC devices.  HTTPS will not work.  If you are using SSH, I think you're seeing my relatively new bug CSCtg43962.  If you contact TAC, a patch can be provided to fix this.
mserranocisco Wed, 09/01/2010 - 23:54
There is no bug using Telnet? we have configured both, if ssh is failing, we can use telnet, but it is not working neither...
Joe Clarke Thu, 09/02/2010 - 08:45
No, telnet is not affected.  However, you may need to restart ConfigMgmtServer before trying it.  Run:
pdterm ConfigMgmtServer
pdexec ConfigMgmtServer
Then try a config sync using telnet.  You will need a proper username and password configured in DCR for this to work.
mserranocisco Fri, 09/03/2010 - 01:02
Thanks Joseph.
Yes, I have telnet and ssh properly configured, Read Community is failing with:Failed to get value, but snmpwalk is working fine!
I executed what you suggested, with the same result :-(
I have incremented response time for the job, as recomended in the error, with no success.
What else?
Thanks again....
Joe Clarke Fri, 09/03/2010 - 23:55
If you're getting the same job timeout error, even with telnet, you're going to need to get a thread dump of the ConfigMgmtServer process.  Open a TAC service request, and they will walk you through the steps to do this.
You will also need to fix the SNMP issue.  I recommend you re-enter your SNMP credentials for this device in DCR.  A sniffer trace of the Device Credential Verification job will tell you what credentials RME is using, and how the WLC is responding.
