"ERROR: Routing is not allowed on the Management VLAN".
Aug 31st, 2010
Hi all ¡¡¡¡
I have a  power connect  6220 stack with 2 units(its a dell chasis but the switch its a cisco).
I have only one vlan in the stack(vlan 1). When i try to established a interface for vlan 1 i have the error message "ERROR: Routing is not allowed on the Management VLAN".
¿If i want to routing in this stack i need to create another vlan? really i want to etablish vlan interface to te vlan 1 to can routing?
Why i have this error? If i make ip address xxxxxxx this addres can routing or its only to manage vlan 1?
Thanks all ¡¡¡¡¡
vmiller Tue, 08/31/2010 - 11:59
  • Gold, 750 points or more
Those appear to be Dell switches. Have you contacted them or check the documentation ?
yes you would need another vlan or vlans for routing.
The message is pretty clear, no routing on the management vlan.
extrandubi Wed, 09/01/2010 - 01:41
Thanks for the reply. Logicaly if i establish a default
gateway in the same network of the ip address of the management vlan i don't have routing.
rducombl Wed, 09/01/2010 - 04:10
  • Cisco Employee,
Likely those switch do not allow routing and are pure L2 switches that do not allow more than one L3 interface at a time.
but as said earlier better check with Dell documentation.
ROland
