CallerID information (from PSTN) to the Cisco Phones
Hi All,
I would like to know what command I have to set on the voice gateway (3800 series) in order to get or pass the callerID information to the Cisco Phones, I have ISDN PRI (T1) , also those are MGCP (CCM 4.1 controlling) , the telco has the callerid feature actived.
controller T1 2/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Serial2/0/0:23
no ip address
isdn switch-type primary-5ess
isdn protocol-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 2/0/0:23
Please your inputs.
Andres
Aaron Harrison Tue, 08/31/2010 - 09:43
  • Community Spotlight Award,
    Member's Choice, May 2015
You mean callerID in number format, or name?
If number, it's there by default; run a 'debug isdn q931' on the gateway to verify the SP has actually got it turned on (you should see the info in the RX SETUP packets even if CCM was ignoring it).
Aaron
Yes caller-ID number format,  the scenario is the following:
PSTN-----(T1)----->Nortel PBX-----(T1)------>Cisco Gateway---->CCM--->phones
Actually when an incoming call is send to a phones, those are receiving on the display the  “call Fwd to 3XXX”.  what is the same extension number (it self) (called party number)
ALNVGATE1#
Aug 31 17:48:02.060: ISDN Se2/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x17
        Bearer Capability i = 0x8090
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xE9808397
                Exclusive, Interface 0, Channel 23
        Calling Party Number i = 0xA2, '7723903400'
                Plan:Unknown, Type:National
        Called Party Number i = 0xA2, '33212'
        Redirecting Number i = '"', 0x008F, '3212'
Aug 31 17:48:02.084: ISDN Se2/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x97
        Channel ID i = 0xA98397
                Exclusive, Channel 23
ALNVGATE1#
Aug 31 17:48:02.088: ISDN Se2/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x97
        Progress Ind i = 0x8088 - In-band info or appropriate now available
ALNVGATE1#
Aug 31 17:48:14.332: ISDN Se2/0/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x97
        Display i = 'Voicemail'
Aug 31 17:48:14.336: vtsp_call_ssrc_update: updated ssrc=0x16BCA055
Aug 31 17:48:14.356: ISDN Se2/0/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x17
ALNVGATE1#
Aug 31 17:48:30.771: ISDN Se2/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x17
        Cause i = 0x8190 - Normal call clearing
Aug 31 17:48:30.787: ISDN Se2/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x97
Aug 31 17:48:30.803: ISDN Se2/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x17
Thxs
Andres
