ACS certificate renewal
Aug 31st, 2010
Hi all,
It's time for me to renew the certificate on a ACS appliance running 4.2
For renewal, what is the process to follow?
I am using a Windows 2003 CA.
aosandoval Tue, 08/31/2010 - 11:12
Hi Waris,
The link seems to be broken...
By renewing the certificate, will all clients be affected?
or is only between the ACS and Windows?
Waris Hussain Tue, 08/31/2010 - 11:35
I have attached the equivalent PDF  file for the link.
Assuming you are using certificate for PEAP the new certificate might come with new serial number and client may be asked to install the certificate.
Waris Hussain.
aosandoval Tue, 09/07/2010 - 13:04
Hello Waris,
I would like to thank you for your feedback on this discussion.
I was able to renew the certificate in the ACS without a problem.
Khaled Abuelenain Wed, 02/09/2011 - 03:49
Can you share with us how you renewed the certificate without having to install a new one ? I'm running into the same problem - I need to renew the certificate without having to install a new one on all the devices. I'm using ACS SE 4.2.
