08-31-2010 12:31 PM - edited 03-13-2019 07:07 PM
I have a DMP 4400 and I'm trying to control display power on and power off with the rs232 serial port. I have a non cisco display.
I used the following set command in advance task on DMM 5.2.1 to activate rs232 functionality on a specific DMP:
init.startService_rs232=yes&rs232.device=/dev/ttyS1&mib.save=1&mng.reboot=1
After the DMP reboots, it starts operating at a much slower speed. It takes several minutes for the startup splash screen to disappear. After that finally happens, my content takes an unacceptable amount of time to load. It can take a minute or too for my content to load from the initial screen wipe from black, which also occurs at a snails pace. Even after all that the rs232 controls aren't ever leaving the port. I hooked it to my laptop and confirmed this.
If I deactivate rs232, the DMP begins operating at normal speed. I also ran the same command on a DMP 4305. It worked just fine. I had total control over the TV.
Does anyone have any idea?
Thanks in advance.
08-31-2010 03:17 PM
Wesley,
I have not seen this issue personally, but did see a case where another
customer has the same issue. The problem actually turned out to be the
RS232 cable itself.
The customer had multiple DMPs configured for RS232 and was only experiencing
the issue on one DMP. The Cables tested fine and the pinouts within specification.
After swapping the cable from a working configuration to the DMP experiencing the
slowness, the DMP performed as expected.
* So one suggestion would be to try the serial cable from another DMP configuration.
* Another thing to try is to reset or restore the problem DMP to factory defaults. After it
reboots, reconfigure as needed to work in your DMS environment. Then, test your content
prior to adding RS232 support. After the content is played as expected, configure the DMP
for RS232 support and test the content performance again.
If the problem persists, please provide the detailed output of the "status" mib for the
DMP in question.
T.
09-01-2010 04:48 AM
Hi wesley,
I haven't experienced this situation before but maybe the following will help you.
Turn on the dmp cache in association with the internal storage read and write option.
Also, enable the logging option, change the ip to :127.0.0.1 and then disable it again.
Save,reboot the dmp and test your DMP performance.
I hope that this will help you
