ESW 540 24-Port and GIBICs
Aug 31st, 2010
hello is there a way to properly configure the GIBICs on these switches?
I  have 2 EXS540-24 port on Switch 1 i have the GIBIc on port GE3 on Switch2 I have the GIBIC on port Ge4,
however on Switch1 port 12, i can't connect anything it looks like the GIBIC on GE3 is using it
on Switch2 port 24 same thing
is there a way to fix this ?
Glenn Quesenberry Wed, 09/01/2010 - 08:58
  • Cisco Employee,
That is normal behavior as those ports share switch fabric resources with the GBICs.  When installed the GBIC will have priority and the associated ports (12 & 24) will not be operational.  You seem to have them configured correctly.
Best Regards,
