08-31-2010 01:12 PM - edited 03-13-2019 07:07 PM
The upgrade path in the manual is:
•5.0.3 > 5.0.2 > 5.1 > 5.2
How do I get from 5.0.3 to 5.0.2?
-Randy.
08-31-2010 01:33 PM
README -- Upgrade Helper Patch for Cisco Digital Media System (DMS) 5.0.3
There is no patch that upgrades Cisco DMS components directly from release
5.0.3 to release 5.1. Instead, we built the "helper" patch that this README
file describes.
First, you must apply the helper patch to any Cisco Media Convergence
Server (MCS) appliances on which you run DMM 5.0.3 and Video Portal
5.0.3 software. There is only one helper patch, which works correctly to
prepare either of these server types for upgrade to 5.1.
After you apply the helper patch to your server appliances, you can upgrade
them to release 5.1 as if you were upgrading from Cisco DMS release 5.0.2.
NOTE: We developed and released Cisco DMS 5.0.3 after we developed and
released Cisco DMS 5.1. Therefore, when you upgrade from 5.0.3 to 5.1,
you reintroduce four known bugs (which existed in the 5.0, 5.0.1, 5.0.2,
and 5.1 releases) that we fixed in the 5.0.3 release. We plan to fix
these same bugs in a future patch release for Cisco DMS 5.1. You can use
Bug Toolkit on Cisco.com to read about these bugs.
- CSCsu90536
- CSCtb84765
- CSCte65316
- CSCsu10293
Obtain the Helper ISO
1. Log in to your Cisco.com account, and then go to:
http://tools.cisco.com/support/downloads/pub/Redirect.x?mdfid=281723656.
2. Click Expand All, and then click Cisco Digital Media Manager.
3. Click Expand All, and then click 5.1.
4. Click the name of the "dms503helper.iso" file.
5. Click Download.
6. Stop. You have completed this procedure.
WHAT TO DO NEXT:
- Verify the download.
Verify the Download
1. Confirm that you downloaded these two files:
- dms503helper.iso -- Digital Media Manager appliance software
- dms503helper-readme.txt -- This README file
2. Verify that the ISO file has this md5sum: 0A65557B8BE942E2EFD3B3085C1C682D.
3. Verify that the ISO file is exactly this size: 391168 bytes.
NOTE: md5sum is a GNU utility. You can downloaded it from
http://www.gnu.org/directory/textutils.html.
4. Stop. You have completed this procedure.
WHAT TO DO NEXT:
- Patch your appliances.
Patch Your Cisco DMS 5.0.3 Appliances
1. After the download is finished, burn the ISO to a CD-ROM.
2. Apply the helper patch to your DMM 5.0.3 appliance.
a. Insert the CD-ROM into the appliance CD drive.
b. Start AAI.
c. Choose APPLIANCE_CONTROL > SOFTWARE_UPDATE, and follow the prompts.
d. Eject the CD-ROM from your DMM appliance.
3. Apply the helper patch to your Video Portal 5.0.3 appliance.
b. Start AAI.
d. Eject the CD-ROM from your Video Portal appliance.
4. Follow the upgrade instructions in the guide at this URL:
http://www.cisco.com/en/US/docs/video/digital_media_systems/5_x/5_1/dms/upgrade/guide/dms51upg.html
5. Stop. You have completed this procedure.
