Installing a Netflow Service Card for a Supervisor V
Aug 31st, 2010
Is there any installation procedure to install a Netflow Service Card (WS-F4531=) on a Supervisor V (WS-X4516)?
I can only find a procedure to do it for a Supervisor IV, but i am not sure if this procedure is valid for a Supervisor V.
Pedro
kyukim Tue, 08/31/2010 - 18:48
  • Cisco Employee,
There should be no difference between SUP IV and SUP V for installation procedure.
Hardware and Software Requirements
To install and use the NetFlow Services Card, you need the following:
Catalyst 4500 series switch (Catalyst 4503, 4506, 4507R, or Catalyst 4006)
Supervisor Engine IV or Supervisor Engine V running Cisco IOS Version 12.1(13)EW or greater
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/78-15214.html#wp59422
IOS CONFIG GUIDE
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/20ew/configuration/guide/nfswitch.html
KK.
