Need help setting up an auto attendant or call handler
Answered Question
Aug 31st, 2010
Hi all,
I need to take a DID and point it to a call handler or AA so that it gives the caller some options. I am running CUCMBE 6.1 currently.
I have setup the direct routing rule so that when the incoming call comes in it goes to the system call handler. When you call the number it says that it cannot be completed as dialed.
Correct Answer by David Hailey about 6 years 6 months ago
you should configure a CTI route point for redirection to VM.  configure the main line as a DN forwarded to VM for the AA.  then you can configure the main number directly on the CH or use a forwarded routing rule to route to the main CH.
hailey
please rate helpful posts!
Overall Rating: 4.5 (2 ratings)
Bradford Magnani Tue, 08/31/2010 - 14:23
Does the call actually arrive at UC's ports? Or is the message coming from the phone system side (CUCM) like it can't determine how to send the call to UC? You can use RTMT's Port Monitor, or download Remote Port Status Monitor from ciscounitytools.com to observe where in the call flow it may be breaking down.
TGettle0001 Tue, 08/31/2010 - 14:41
thanks for quick response.
If I set the translation to point it to the main AA it works as it should, but when I set it to use the newly created direct routing rule it then gives the error message when I call in. I will try the tools and see what I find.
Correct Answer
David Hailey Tue, 08/31/2010 - 16:44
hailey
TGettle0001 Wed, 09/01/2010 - 13:37
Thanks for the help, I just needed to setup the Hunt pilot in CUCM. I had everything done and ready in unity, it just couldnt do anything with the call because it was not a valid # until I set it up.
Related Content
