ASA 5510 remote access and traceroute problem?
Answered Question
Aug 31st, 2010
We have L3 3750 (InterVlan Routing) with created vlans on it without any restriction between. ASA 5510 is connected on one trunk port on L3 switch with Eth 0/1.1, 01.2,.. subinterfaces for each vlans (for policy rules for limiting bandwith). On Eth 0/2.1 is outside interface with static address e.g. 88.88.88.90 on vlan 50, def route is 88.88.88.89. Static NAT with network-object for each network.We use 8.8.8.8 google DNS.
Problem: All natted network can go to the Internet and thats ok. But when we do tracert from any Internet enabled host it goes only to its gateway (vlan ip) and stops. We cant ping our outside interface 88.88.88.90 from inside networks. And also we cant ping public address from any home PCs-other ISP address 88.88.88.89 we are pinging without any problems. What's the issue here?
What about def route from L3 swith - we don't need any right?
How we can connect to ASA from outside (https,vpn) for management? We created remote vpn, but nothing happens. We permited all traffic to outside intraface, permited icmp,... all permited on in LAN interface, there are no restrictions.
Any help?
Correct Answer by Nagaraja Thanthry about 6 years 9 months ago
In order for you to ping/traceroute internet destinations, you need to allow
return ICMP traffic on the outside interface. Other way would be to enable
ICMP inspection.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note...
6a0080094e8a.shtml
If you would like to manage the firewall from outside (connecting to outside
interface), you need to exclusively enable it. I would not suggest you to
open it up for everybody. If you have a static IP range that you would like
to use when accessing the firewall, then you can configure the following:
Http server enable
Http "IP address" 255.255.255.255 outside
Ssh "IP address" 255.255.255.255 outside
Telnet is not allowed from outside interface. If you are using SSL VPN, then
there could be a conflict of ports on the outside interface. In that case,
you might have to change the port on one of the services i.e. ASDM or WebVPN
(both use port 443).
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Tue, 08/31/2010 - 14:55
  • Cisco Employee,
Can you please post the relevant configurations here?
NT
Correct Answer
Nagaraja Thanthry Tue, 08/31/2010 - 15:00
  • Cisco Employee,
ICMP inspection.
6a0080094e8a.shtml
Http server enable
Hope this helps.
NT
