How to allow my aef CRS script take effect?
Answered Question
Aug 31st, 2010
Hi All,
I just modified the aef script in IPCC server. Unfortunately, after I saved it. It seems still behave the old way. Is there anything I should do to make the updated script take effect?
Thanks!
Lou
Correct Answer by Aaron Harrison about 6 years 7 months ago
Or rather... you can, but you then have to go around the various screens anyway to refresh the script into memory/local storage on each server.
Option 1 ) Go through the 'Script Management' page, upload, then hit 'Yes' to refresh the script and the application. It should now be 'live'.
Option 2 ) Open from the Repo, save to the Repo. Script is not live. Go to Script Management, hit the 'refresh' icon for the edited script. Then go to 'Application Management' and hit 'refresh' for the application.
If it's still not live, there may be a problem... but in general it's easier overall if you go through the upload page as Tracy suggested (+5). It also means it's easier to keep a history of edited files without cluttering up the server (you can keep lots of versioned filenames on your local disk and then 'Upload as...' the name already on the server so that you don't have 8000 files to scan through when picking scripts for applications or debugs).
Aaron
Please rate helpful posts..
Correct Answer by Tracy Larson about 6 years 7 months ago
did you download the script from the server, then make your edits then go through the upload process? You cant just edit the script with the editor by pulling it out of the script repository and clicking save.
Overall Rating: 5 (4 ratings)
Correct Answer
Tracy Larson Tue, 08/31/2010 - 16:22
  • Silver, 250 points or more
Correct Answer
Aaron Harrison Wed, 09/01/2010 - 01:29
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
