Swapping phones conflict
Answered Question
Aug 31st, 2010
I tried to swap two phones (using a dummy MAC in the process), but I'm running into the following error.  I've tried tracking down the device in question but with no luck.  I'm using Cisco Call Manager 4.1(3)
"The MAC address you entered is already assigned to the following device(s):
3133_SEP001818FD515CC
Please check the MAC address for each device and make sure it is correct."
Correct Answer by Aaron Harrison about 6 years 8 months ago
That device name looks like a UDP - if you convert phones to UDPs, they get the username_phonename format. I'm guessing 3133 is a user that had SEP001818FD515CC associated.
At any rate, check under Device/Device Settings/Device Profile, I guess that UDP must refer to one of the phones you are renaming in some way?
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Wed, 09/01/2010 - 01:32
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
