Re: AP cant get DHCP address
Aug 31st, 2010
Hey all,  I'm hoping someone can help with a problem I am having with a AIRONET 1130AG Access point.
I have installed quite a few of these but this one has me baffeled.  Now, I'm not a CCNA or anything like that.
I set up using the GUI;  I use a simple WPA.
My devices connect with "Limited or no Connectivity"    If I hard code an address, devices work fine.  If I attach them to the switch, they obtain an address on the nic AND the Wirless connections.
If i check the AP,  it shows my devices, but no IP.  Under the log, the last entry say  "interface Dot11Radio0, Deauthenticating Station (mac address) reason:  Previous authentication no longer valid"
Any advice is greatly appreciated.
John
