SIP Trunk transfers to voicemail and auto attendent
Answered Question
Aug 31st, 2010
Having issues with my dial-peers and voice translation rules converting from a PRI to SIP trunk (see attached).
Correct Answer by Steven Holl about 6 years 8 months ago
CUE isn't responding to the INVITE which it is being sent.  Are you sure that you can ping 192.168.69.200 from CME?  If you've changed the IP on CUE recently, have to reloaded CUE since then?
Here is the INVITE to CUE which gets no response:
Sep  1 11:50:50.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.69.1:5060;branch=z9hG4bK191EC85
To:
Date: Wed, 01 Sep 2010 11:50:50 GMT
Call-ID: [email protected]
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 3360103-3036025311-3016158435-3896829911
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1283341850
Contact:
Call-Info: ;method="NOTIFY;Event=telephone-event;Duration=2000"
Diversion: ;privacy=off;reason=no-answer;screen=no
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 4166 5167 IN IP4 192.168.69.1
s=SIP Call
c=IN IP4 192.168.69.1
t=0 0
m=audio 17818 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
Overall Rating: 5 (1 ratings)
Steven Holl Wed, 09/01/2010 - 06:18
  • Cisco Employee,
What is the specific issue which you are seeing?  Just attaching a configuration and saying you are having a problem isn't enough for someone to help you fix your issue.
Run the following debugs during a call failure:
debug voip ccapi inout
debug ccsip mess
Douglas Yoder Wed, 09/01/2010 - 06:21
Sorry about that, here is the debug and when the call gets transferred to AA or Voicemail the system returns a "all circuits are busy" message.
Correct Answer
Steven Holl Wed, 09/01/2010 - 06:29
  • Cisco Employee,
Sent:
To:
Min-SE:  1800
CSeq: 101 INVITE
Contact:
Expires: 180
Max-Forwards: 68
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
Douglas Yoder Wed, 09/01/2010 - 07:32
That was it, got a little carried away with the static routes and accidently routed the CUE to the SIP Trunk. Removed that and all is good. After a late night working on this I figured it was something simple I was over looking. Thanks Steve.
Related Content
