pix 515 pdm and java
Sep 1st, 2010
i've got a problem to access to the pdm
i'm using :
Cisco PIX Firewall Version 6.3(1)
Cisco PIX Device Manager Version 3.0(4)
i thought that this version of pdm resolve the propblem with java version but with the last version of java 1.6.21
i've got this error message :
"java.lang.ArrayIndexOutOfBoundsException: No such child: 0"
on firefox 3.6.8 and ie8
i dont know how to resolv this problem
is there a solution ?
thanks by adavnce for your help
Kjellstrup Wed, 09/01/2010 - 04:08
They har major quality problems with ASDM for a long time in the same time period as your PDM was made (2005), so I assume the only "solution" is to run old, dangerously insecure java.
- not that it is a acceptable solution.
(they required specific java versions back then)
Kureli Sankar Wed, 09/01/2010 - 05:56
  • Cisco Employee,
Download PDM again and install it: pdm-304.bin
Give it a shot.
http://www.cisco.com/en/US/docs/security/pix/pix60/pdm10/installation/guide/upgrade.html
I would also remove the existing pdm lines.
sh run | i pdm
only add the lines that are required.
Browser requirements: http://www.cisco.com/en/US/docs/security/pix/pix60/pdm10/installation/guide/install.html#wp1036583
-KS
pascal.legrand Thu, 09/02/2010 - 00:37
hello,
in first thanks for your answer, but i'm not sure to understand what you told me to do.
i made the upgrade of the pdm to the 3.0.4 version.
now i would like to use a new version of java jre but it still doesnt works.
i've got always an error message.
sorry if i didnt understand your message
i'm not sure to understand what means "give it a shot"
my problem seems to be only about java but i'm not sure
thanks again
Kureli Sankar Mon, 09/20/2010 - 20:25
  • Cisco Employee,
What I meant was to upload the pdm file to the firewall one more time with this command
copy tftp flash:pdm
You can also try the following.
1. try a different browser
2. try a different computer
3. login as local administrator to the computer and try to launch pdm
-KS
pascal.legrand Mon, 09/20/2010 - 23:07
Here is what i done to make it works
PDM 3.0(4) works with JRE 1.6 update 10
PDM access works with ie8 and 1.6 update 7
The last version of firefox works jre 1.6 update 15 at least
Then i use JRE 1.6 update 7
and firefox 3.5.11
it works also with ie8
thanks
jordanmed Sun, 09/19/2010 - 08:38
I am not able to download that pdm file... Could you activate the link for me? I have an old PIX 515E and I cant find that download anywhere on the cisco site. Just says the file is not available. Appreciate any help. Thanks.
