LMS3.2 Syslog reports very slow when send via email
Sep 1st, 2010
we have ~5000 devices in LMS3.2 and we have a problem with syslog reports.
When I create a "severity level summary report" for 5000 devices for the last 24hours and select as run type "immediate" it needs ~2-3 minutes. That's ok.
But when I create exactly the same report and select the run type "once" , it needs ~3 hours. ("Once" means that the report is send via email after it's finished).  It happens with report type "pdf" and "csv".
What can be the problem ?  Or is it usual ???
Hendrik
Joe Clarke Wed, 09/01/2010 - 21:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The scheduled reports can output a full list of messages where as the immediate reports output a limit of 10,000 records.  If you have a lot of syslog messages, it can take a considerable amount of additional time to generate a full report.
