Unsupported Device on CCA 2.2(4)
Answered Question
Sep 1st, 2010
Dear All,
I used CCA version 2.2(4) to connect to my CME 2811 Router. First I was asked to key in the password for "level_15 or view_access" and second it asked me again to provide password for "Admin". After giving all credentials, I can only see one unsupported device in red icon from CCA window.
Please help me on how do I connect to my CME router by using CCA.
Andrew
Message
Please enter your username and pwd for realm "level_15 or view_access" on x.x.x.x
Please enter your username and pwd for realm"Admin" on x.x.x.x
Correct Answer by Felipe Garrido about 6 years 4 months ago
Andrew,
CCA is only meant to be used with the Small Business Products ( UC5x0, CE5x0, etc). If, you want a GUI based configuration tool for CME, try CCP.
http://www.cisco.com/en/US/partner/products/ps9422/index.html
-Felipe
Correct Answer by Paolo Bevilacqua about 6 years 4 months ago
If you are looking for professional results, to understand how CME works, and cannot afford to loose your time, avoid CCA, and use CLI only.
Overall Rating: 4 (2 ratings)
Correct Answer
Paolo Bevilacqua Wed, 09/01/2010 - 03:17
Andrewkai Wed, 09/01/2010 - 20:45
Hi Guys,
I just wanted to know why am I getting unsupported device error?
Thanks for your kind support!
Andrew
Related Content
