09-01-2010 03:37 AM
Hi Everyone,
How do I upgrade to Common Services 3.0.6? I am currently using Cisco3.0.6. I have already run the perl command for cwcs306-win-CSCtd01597-K9 but it is not reflecting that Common Services is 3.0.6.
Thanks a lot.
Solved! Go to Solution.
09-02-2010 01:58 AM
ok, now I understand. CS 3.0.6 is provided as "Common Services 3.0 Service Pack 6 (CS 3.0.6)". It is provided as a strong crypto patch and can be downloaded here (CCO Login needed):
http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des
09-01-2010 07:19 AM
please post a screenshot of
CS > Software Center > Software Update
09-01-2010 06:41 PM
I cannot provide you with a screenshot right now. But the current Common Services version is 3.0.5.
09-02-2010 01:58 AM
09-02-2010 04:33 AM
Thanks a lot mermel. I have the installer now.
09-02-2010 06:01 AM
fine that I could help!
I published a document that gives an overview about the different LMS versions and the associated applications - perhaps this can also help you in some way
09-13-2010 03:08 AM
Thanks a lot.
