Disable Remote Management on RVS4000
Sep 1st, 2010
I enabled remote management on my RVS4000, which now works fine.
For security reasons I would like to disable it but the option is greyed out, as are the HTTPS and Remote IP address options as a matter of fact.
Can anyone tell me how to overcome this?
Thanks in advance.
Te-Kai Liu Wed, 09/01/2010 - 07:11
The option is grayed out since you are coming into the router from a remote management session. Try to disable it over a QuickVPN tunnel, or do it from the LAN side of RVS4000.
