Caller ID problems
Sep 1st, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
I face a big problem
I have system voice(CM6 + CRS + GW + 4 FXO + PRI E1)
when anybody calls me >>>> the call succeed but the caller Number
presentation delivered with errors
Example:
ORiginal No.:   0101060624
Received No.: 0 01060624
ORiginal No.:     23959966
Received No.:  2999966
ORiginal No.:   0122422645
Received No.: 091 422645
and so on
Please advise ASAP
Felipe Garrido Wed, 09/01/2010 - 07:06
  • Cisco Employee,
how does the voice gateway integrate with CUCM (MGCP, H323, SIP)? Do the calls come in from the FXO ports or PRI?
If, not MGCP, can you provide the following info from the gateway,
show run (feel free to remove an sensitive info)
-Felipe
a_mohammedy Thu, 09/02/2010 - 02:46
Dear Sir,
Thanks for your support and followint my answers:
how does the voice gateway integrate with CUCM (MGCP)? Do the calls come in from the FXO ports or PRI? the calls come in from PRI
Abdelhai
