UCCX 7.X license seats in use
Answered Question
Is any way to check on real time, how many licensed seats are being use. I have found that the agents logged-in info is not the same as the number of license seats in use, for example, if an agent logoff from the CAD it doesn't show anymore on agents logged-in but if the CAD remains open it is still using a seat.
thanks,
Oscar Perez
Correct Answer by Aaron Harrison about 6 years 6 months ago
Run showlicenseusage.exe from c:\program files\cisco\desktop\bin. Use a cmd window on the server to run it....
Aaron
Please rate helpful posts..
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Wed, 09/01/2010 - 05:58
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Hi Aaron,
I can run this file on demand but what would you recommend for me to monitor the uccx user seat usage. I had some license applied and they felt short after few extra users signed in and this logged off current users.
I think there might be RTMT but I am guessing that is for UCCX 8.0 But I have UCCX 7.0.1
Any suggestions?
K
