FTP issue
Sep 1st, 2010
I have a server on a dmz that can ftp a file using the web browser and you can connect to the ftp server via the command line.   However, when one of the developers tries to use a script to transfer the file it does not work.  Additionally, when you connect to the ftp server via the command line and try to run the ls command you receive an error message saying " 500 illegal port".
I know that ftp is allowed on the firewall and ftp is part of the default global inspection policy.  It looks like this is a PASV vs active issue.  However in windows it does not allow you to swtich to passive mode.
Other then opening up all high level ports for this connection , does anyone have a suggestion on what/ if anything I can do on the firewall?
thank you
praprama Wed, 09/01/2010 - 07:37
  • Cisco Employee,
Hey,
Could you provide details as to where is the client located with respect to the ASA and also IP address details of the ASA and the server along with the current ASA config (with altered IP addresses if needed)? We can go through that and see if we notice anything wrong on the ASA.
Thanks and Regards,
Prapanch
lkadlik Wed, 09/01/2010 - 08:33
The client is on the dmz and can connect to the ftp server via the command line and transfer the file using a browser.
a.b.c.f is the ftp server
a.b.c.g is the client
The relevant parts of the config are as follows:
ASA Version 8.0(3)
interface GigabitEthernet0/0
speed 100
duplex full
nameif outside
security-level 0
ip address a.b.c.d 255.255.255.0 standby a.b.c.e
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.20.30.2 255.255.255.0 standby 10.20.30.3
interface GigabitEthernet0/2
interface GigabitEthernet0/2.1
description LAN Failover Interface
vlan 28
interface GigabitEthernet0/2.2
description STATE Failover Interface
vlan 29
interface GigabitEthernet0/3
speed 100
duplex full
nameif dmz
security-level 50
ip address 192.168.50.2 255.255.255.0 standby 192.168.50.3
interface Management0/0
shutdown
nameif managment
security-level 100
no ip address
same-security-traffic permit inter-interface
object-group network FTP
network-object host a.b.c.f
object-group service FTP_service
service-object tcp eq ftp-data
service-object tcp range 5500 5700
access-list acl_Inside extended deny object-group Anonymous any object-group BlackList
access-list acl_Inside extended deny ip a.b.c.0 255.255.255.0 any
access-list acl_Inside extended deny ip 192.168.50.0 255.255.255.0 any
access-list acl_Inside extended deny ip host 255.255.255.255 any
access-list acl_Inside extended deny ip 127.0.0.0 255.0.0.0 any
access-list acl_Inside extended permit ip any any
access-list acl_DMZ extended permit tcp host 192.168.50.51 host 192.168.50.180 eq smtp
access-list acl_DMZ extended permit tcp host 192.168.50.54 host 192.168.50.180 eq smtp
access-list acl_DMZ extended permit tcp host 192.168.50.54 host 192.168.50.246 eq smtp
access-list acl_DMZ extended deny ip 192.168.50.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list acl_DMZ extended permit ip 192.168.50.0 255.255.255.0 any
access-list acl_Outside extended permit object-group FTP_service any object-group FTP
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu managment 1500
asdm image disk0:/asdm-623.bin
no asdm history enable
arp timeout 14400
static (inside,outside) a.b.c.f 10.20.30.55 netmask 255.255.255.255
static (inside,outside) a.b.c.g 10.20.25.102 netmask 255.255.255.255
access-group acl_Outside in interface outside
access-group acl_Inside in interface inside
access-group acl_DMZ in interface dmz
policy-map Global_Policy
description Global Policy for Traffic Inspection
class Inspection_Default
inspect dns
inspect ftp
inspect h323 h225
inspect h323 ras
inspect icmp
inspect ipsec-pass-thru
inspect mgcp
inspect pptp
inspect rsh
inspect rtsp
inspect sip
inspect skinny
inspect snmp
inspect sqlnet
inspect tftp
inspect xdmcp
inspect http
service-policy Global_Policy global
prompt hostname context
Cryptochecksum:fd174eacd4f91d6b5b3ef484f5365abe
: end
praprama Wed, 09/01/2010 - 08:40
  • Cisco Employee,
You have mentioned that both the client and the serve rare on the DMZ. But in the config i see the below 2 static commands redircting a.b.c.f (server) and a.b.c.g (client) to the inside interface.
I am not quite sure about the topology yet. Could you clarify things a little bit more here?
Prapanch
lkadlik Wed, 09/01/2010 - 14:47
It looks like this might be a barracuda issue.  Thank you for taking the time to respond to me
Related Content
