09-01-2010 07:56 AM - edited 03-06-2019 12:46 PM
One of my coworkers is trying to implement Site to Site IPSec tunnels over MPLS and i wanted to know is this possible
Solved! Go to Solution.
09-01-2010 08:37 AM
An IPsec tunnel is established between two VPN endpoints.
The underlying transport method does not matter.
I guess that if the MPLS is provided by you by an ISP, then unless they are denying the establishment for IPsec, you should be able to configure the IPsec tunnels fine.
Federico.
09-01-2010 08:37 AM
Federico.
09-01-2010 09:06 AM
09-01-2010 02:42 PM
Here is a link that will help you
http://www.blindhog.net/cisco-how-to-configure-an-ipsec-vpn/
and also attched file that explin the basic configuration
