looking for a document listing the supported cameras in VSOM6.3
Sep 1st, 2010
I need to get a document listing the exact cameras supported in the VSOM latest release to check if my customer's one are inside or not.
I tried to find documents on CCO event through the software download links of the driver packs, but nothing.
It looks like this part of the software is not well documented (maybe to avoid client to buy other cams than Cisco's ones ;-)
Do somebody having a doc on this and maybe on next supported camera roadmap ?
My customer is having MOBOTIX cams since quite long and he want ot keep it, so I need to know if it is/will be supported.
Thanks a lot.
Herve C.
Senior Network Engineer.
DIMENSION DATA Luxembourg.
