Partial/fractional T1 PRI card
Answered Question
Sep 1st, 2010
Hi all,
we're running a 2911 router and are just about to order a card to support a new PRI service that we are pulling in. It is a 'starter pack' PRI from our telco and this is a fractional/partial T1 PRI with 10 voice lines available (instead of 24). Does anyone know if the VWIC2-2MFT-T1/E1 card supports partial PRIs?
I assume (on the router side) it's all in the command 'pri-group timeslots 1-10' instead of '1-24', but without the actual card available I can't check it, or find much in documentation about support...
cheers,
Alan
Correct Answer by Steven Holl about 6 years 11 months ago
The card supports fractional PRI, but this isn't supported with MGCP.  You need to run H323 if you run a fractional PRI if you want TAC/development support.
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K14305072
With MGCP, you can get by with busying out the channels in CM and disabling MGCP config server, but again, it won't be supported if you run into issues.
Correct Answer by paolo bevilacqua about 6 years 11 months ago
Of course, it supports "partial PRI".
Overall Rating: 4.8 (3 ratings)
Correct Answer
paolo bevilacqua Wed, 09/01/2010 - 09:01
  • Hall of Fame,
    Founding Member
Correct Answer
Steven Holl Thu, 09/02/2010 - 06:39
  • Cisco Employee,
a.brazendale Thu, 09/02/2010 - 06:51
Thanks for the replies guys. I'll look up both options, maybe the H323 option is the better just to stay on the support side.
paolo bevilacqua Thu, 09/02/2010 - 07:08
  • Hall of Fame,
    Founding Member
H.323 or SIP will actually give you much more than being support side.
Thank you for the nice rating and good luck!
